Maj 09 2024 00:04:33
27% [6 Röster]
32% [7 Röster]
18% [4 Röster]
Röster: 22
· Komplett felsökning... 6939
· TrÃ¥dar, poster, Vol... 43010
· Alla Ã¥tdragningsmom... 18946
· NY GUIDE Omklädsel ... 15988
· Byta kamrem pÃ¥ volv... 12699
· Besök Volvoswedens ... 10168
· Lösning pÃ¥ Felkod ... 10127
· Guide pÃ¥ hur man po... 9969
· Vill du starta en pr... 9561
· Spola rent kylsystem... 9510
Tråd ID: 613
Det är 1 svar i den här tråden, och den har visats 38808 gånger.
Volvo 850 how to change Timing Belt
We got this How to change Timing Belt for Volvo 850 in our mailbox. This DIY guide is all shown with pictures and is explained in the English language. The timing Belt for the Volvo 850 year model 1993 should be changed every 50k miles or every 5 year. If you got a Volvo 850 that is from 1994 to 1997 the Timing Belt should be replaced every 70k miles or 5 year.
Here you can get the Volvo 850 timing belt how to guide https://dl.dropboxusercontent.com/s/g...%20PDF.pdf
Redigerat av Sladdaren den 19-03-2017 17:55
"Den Vite" Volvo 945 Classic -98 (Installad för vintern) Projekt 1556 08-05-2024 22:29
· Besökare: 8
67,580,187 unika besök
